Board index Public Relations Contests JazzLand Inversion Challenge (RESULTS pg22)
Post November 12th, 2005, 4:59 pm
The address is just there to make it seem like an actual letter. I have no idea what WWS's real address is.
Post November 12th, 2005, 5:45 pm
Post November 12th, 2005, 5:57 pm
I would do this, but it seems EVERY single contest out their right now is about how many loops can you make. Also I made a coaster called "The Enjoy Square", it has the 10 inversions already and pretty much fits the criteria except for it needs another loop and the spacing is a problem.
Also you do know that Mega Zeph is doomed right?
Post November 12th, 2005, 6:54 pm
Post November 12th, 2005, 7:38 pm
What is that supposed to mean. Has it rusted or something like that?
Post November 12th, 2005, 7:39 pm
Points on hand: 2,083.00 Points
Location: Etobicoke(Toronto), Is Ontario a state?, Canada
You say track and supports and all that stoof is to be kept in the template? Can mebbe the train itself extend out of the template?
Hopefully you get what I mean...
Post November 12th, 2005, 7:58 pm
yes, the trains can go outside. Just keep the structure in.
Post November 12th, 2005, 9:58 pm
Points on hand: 2,273.00 Points
The only problem with this contest is that Jester sits in part of the field you have allocated, lol. Maybe you should add in a 3Ds Jester ;)
There's no factual basis that Mega Zeph is doomed. Just rumors at this point.
Post November 12th, 2005, 10:01 pm
Points on hand: 3,003.00 Points
Originally posted by hyyyper
Originally posted by mkman7432
Arghh.. the f***** template doesn't work for me. I can never download anything successfully on this site. Wait.. do we even need the template? [?]
post your email adres and i'll send you
and yeah, you do need the template, it has the boundries for the track and station, which increases difficulty
hey HYYYPER here.. it's drew_royal12@hotmail.com
Post November 12th, 2005, 10:03 pm
i started mine, and have a layout in mind, and an idea for a inversion!
Post November 12th, 2005, 10:26 pm
Points on hand: 3,540.00 Points
Post November 12th, 2005, 10:29 pm
This contest is very similar to CS's and Thrillnetwork's most recent contests.
Post November 12th, 2005, 10:35 pm
You can count me in. i'll try and make something special, and that deadline should suffice.
Post November 12th, 2005, 10:42 pm
Q: Does it count as an original element if it's the first to be used on an inverted coaster?
A: If it hasn't been used on an inverted coaster, it is original. You won't get alot of bonus points for it, but it does technically count.
On all inverted coasters(b&m-vekoma) or just the inverted-impuls coaster?
Post November 12th, 2005, 10:43 pm
Post November 12th, 2005, 11:17 pm
Points on hand: 905.00 Points
You know I'm in. Well, maybe you didn't... but now you do.
Post November 12th, 2005, 11:19 pm
sounds like alot of ppl are trying this!! (icl. me)
Post November 12th, 2005, 11:29 pm
Points on hand: 3,926.00 Points
Post November 12th, 2005, 11:41 pm
how much does the track have to be banked for it to be considered and inversion?
Post November 13th, 2005, 12:38 am
It's stated in the rules.
Post November 13th, 2005, 1:13 am
the element must be unique to inverted coasters in general... including Vekomas, Intamins, and B&Ms.
Post November 13th, 2005, 1:30 am
Aside from the max height of 200 feet, this contest bears no resemblance to the thrillnetwork contest whatsoever. The word 'inversion' is shared with the coastersims challenge, and to some extent the multiple inversions sequence thing, but that's about it. The template is much different, there are much fewer restrictions, a different main goal, the coaster type is different, the new inversion thing is different, and what other site has had a contest to build an Intamin SLC? There are some subtle similarities, but all 3 are completely different contests.
Post November 13th, 2005, 2:55 am
Points on hand: 2,601.00 Points
Post November 13th, 2005, 6:23 am
NL contests are populair [;)]
Post November 13th, 2005, 7:13 am
