Board index Roller Coaster Games Hard Hat Area M??????nchner Bahn Recreation
Post April 25th, 2006, 5:01 pm
rcmaniac25 User avatar
I was looking at different coasters when I noticed this coaster called M?????????nchner Bahn. I went to check it out and it turns out only 1 was ever produced. It traveled to 2 parks where it operated, then it was sent to a third where well it was being planned the park closed and it vanished. No one knows where it is currently is. I dicided to make this coaster but their is only 5 pictures of the ride on the internet, might be more but I could only find 5. Currently I have the layout finished and am working on the supports, I'll post it on NLDC in a little while. If anyone can find any information on it, please tell me. Thats all for now.
By the way the coaster's name is Traumlandbahn.
OK here's the link:
http://www.NoLimitsDevCenter.net/p1860
Post April 25th, 2006, 5:18 pm
http://rcdb.com/ig1467.htm There's the link to 2 more pics if you haven't looked at rcdb yet. Good luck at recreating this.
Post April 25th, 2006, 5:39 pm
Ya I found that picture a while a go.
The annoying part about this coaster is its supports, Schwarzkopf has it in a very odd way, and the lack of pictures doesn't help.
Post April 25th, 2006, 11:02 pm
Points on hand: 2,656.00 Points
It's waaaaay too spread out. You can tell from the pics of the actual ride that its drops were much steeper than yours.
Post April 25th, 2006, 11:18 pm
Post April 25th, 2006, 11:37 pm
Nope Real, that's a slightly different model, the one you posted has a curving diagonal first drop while MuncherBahn features a first drop that goes along the left of the layout rather than cut across the layout diagonally.
Also, here's a link to the MuncherBahn on the schwarzkopf site Real referenced: http://schwarzkopf.coaster.net/ESmuenchnerbahnGF.htm
It has stats that should prove helpful in the making of your recreation.
Post April 26th, 2006, 1:15 am
Was that link there when I was looking at it? LOL I totally overlooked that somehow.
Post April 26th, 2006, 7:30 am
Thanks e-man but I already used that site, I still have a lot to work on and compacting the layout is one of them, its like that so I can do the supports easier then I'll make it smaller and it should be correct.
Edit: The Track compacting won't work, when I did it any way it had way to much pumping and it don't fit in with the rest of the coaster, even when I adjusted everything else to it. When I post the track when i'm done, if I get points off all I can say is I tried.
I'll send the track to anyone who would do it, if they wanted to.
Untill then its coming out fine.
Post April 26th, 2006, 5:50 pm
where do you get
from
your whole layout is so stretched.
looks like a case of n00b eyes
Post April 26th, 2006, 9:30 pm
lol sorry bout the pics, thought they'd show up.
anyway, all I'm sayin is that you need to take a look at your layout compared to the real one. yours is VERY stretched out meaning everything is done longer without enough height to compensate for it
Post April 26th, 2006, 10:17 pm
I know, it just isn't working. I might end up making a second one and fixing everything one that one. I noticed many other problems with supports and track on the current coaster.
I'll tell in the morning if i'm going to make a second version and scrape the current one.
Post April 27th, 2006, 12:16 am
Points on hand: 2,063.00 Points
If you want i can shrink it for you using CK. Probably be the easiest way instead of scaping it.
Post April 27th, 2006, 6:56 am
Nah, I made up my mind, I'll just rebuild it. Their are a lot more problems to it then you think. Besides i'm getting lost in the support structure, it'll be easier to rebuild it without supports then to edit the current one.
I can still send you my current one if you want though.
Post April 28th, 2006, 10:40 pm
I finished the new version of Traumlandbahn.
Please tell me what you like, dislike, think is good, or needs improvment on it.
And please tell me if you think I got the demensions right this time. Thats all.[:)]
http://www.NoLimitsDevCenter.net/p1875
