Board index Roller Coaster Games No Limits Coaster Constuction kit help?
Post July 28th, 2010, 4:37 pm
If you have the construction kit could you just transfer a track into a .3Ds file? You will just need to give me the email address and I will send it to you. It sucks not having one program. [:(] Thank You.
Edit 8/26: Bump
Last edited by devilsrule911 on August 26th, 2010, 11:06 am, edited 1 time in total.
Post August 26th, 2010, 2:43 pm
If your end goal is to make scenery around the track, and unless you actually need a model of the track, I recommend using the tunnel maker to make a full-track tunnel. That way, if you make it right you even have clearances pre-checked. Otherwise, I can't help you, since I also am lacking the construction kit [:(]
Post August 26th, 2010, 3:00 pm
Actually, I was going to make 3D supports for the track. I won't need clearance for that. Thanks, and I wont need the help any more since it has already been covered.
