Board index ‹ Roller Coaster Games ‹ No Limits Coaster ‹ Spinning bug on my rocker coaster?
Post January 27th, 2009, 2:47 pm
When I enable unlock spinning on the track segments before and after the station segment, the train will pull down the restraints but not start to move at all. Why is this?
228.29 KB
Post January 27th, 2009, 3:14 pm
Looks like a pretty sweet rocket coaster.
Post January 27th, 2009, 3:55 pm
Um, does your station have friction wheels enabled? It looks like the train won't go anywhere on its own, and spinning shouldn't have any effect on movement.
Post January 27th, 2009, 4:06 pm
Yes they are enabled.
Post January 27th, 2009, 6:37 pm
Um, try enabling a launch on your station, and upping the acceleration or something. You messed up the settings, its not because of spinning.
Post January 28th, 2009, 5:11 am
looking at the ride you need at least another block section to make the car depart the station... That's your problem. It has nothing to do with the spinning locked or unlocked.
Post January 28th, 2009, 11:13 am
Points on hand: 1,575.00 Points
1 block is enough for one car i thought...
Click here!!
Post January 28th, 2009, 11:39 am
#trains = #blocks - 1. So you can run 0 trains. Try adding a block and see if it works. Or disable spinning entirely, so you can rule out the problem is caused by the spinning-settings.
