Board index Roller Coaster Games Hard Hat Area Tempest - B&M Invert
Post January 30th, 2010, 6:38 pm
Points on hand: 62.00 Points
Hey all,
For the past couple of days I've been working on this biatch, and it's actually turning out pretty great. I've always wanted to build one, but never really had the inspiration to because I couldn't make any good B&M elements. Finally newton2 has arrived, and I created this. I don't want to say too much else, so here are some teasers.
Took me a really long time to get the ending right, but it's done now, and I'm happy with it. Also, just to be a bit cocky, I think that the immelman came out spectacular. It just feels and looks so right.
Anyways, if you have any thoughts or comments let me know because they would be extremely appreciated.
Colors and name a pretty final, but if somebody has a ragin' suggestion, who knows. Thanks a bunch to ianko66 for the colors. They came out GREAT.
Cody
@ Gerstlcrazy: I couldn't fit in the little straight section that you loved. Just did not work with the layout. Sorry man!
- RIP Mitch Hedberg
Post January 30th, 2010, 6:41 pm
Points on hand: 1,038.00 Points
Post January 30th, 2010, 6:43 pm
It's um... very realistic....yeah. Everyone remember not to criticize the ride when you rate because otherwise the emo clique will unleash its wrath upon you.
Originally posted by MrPhilly
That first pic made me completely remember that I have multiple usernames.
I fixed it for you.
Post January 30th, 2010, 6:45 pm
Points on hand: 2,837.21 Points
The straight section was awkwardly done anyways. Glad you omitted it.
Post January 30th, 2010, 6:52 pm
Points on hand: 201.00 Points
Post January 30th, 2010, 6:54 pm
I fixed it for you.
How many times do you have to edit your post just to get attention over some lousy joke?
Post January 30th, 2010, 6:55 pm
I had a look at the ride, you are all going to really like this :)
Post January 30th, 2010, 7:02 pm
If you ignore the bad shaping lol
Post January 30th, 2010, 8:17 pm
Post January 30th, 2010, 8:24 pm
Points on hand: 232.00 Points
I love how almost all of us are ignoring him.
BBBuuuuttttt, Matt that post made me laugh.
Post January 30th, 2010, 8:42 pm
Points on hand: 3,634.00 Points
I hope you're going to terraform under that drop? If it is just gonna be 30ft up in the air, it would be disappointing.
The ride looks pretty decent though, although there doesn't appear to be any real creativity to me. Finish it nicely though and it will be pretty good.
Post January 30th, 2010, 8:52 pm
^ Well, I might also point out that this is my first attempt at making a B&M Invert. I realize that this may not be the greatest coaster on the planet, but this is what I could do as a first time attempt. Maybe that will give you all a little more sympathy... lol :)
And yes, I will terraform under there.
- RIP Mitch Hedberg
Post January 31st, 2010, 1:28 am
Points on hand: 827.00 Points
^How did you make the corkscrews? Every time I try I get a really bad transition at the apex, it's deadly.
Post January 31st, 2010, 2:52 pm
^ There called Wing-Overs, and there pretty simple. Just take a multi-zone force, have a lead in and lead out of about 3.5 G's, and the middle zone should be about 1 - 1.5 G's, and rotate about 300 degrees.
- RIP Mitch Hedberg
Post January 31st, 2010, 3:51 pm
Wing-overs, corkscrews, same diff really. Thanks though, I had a tough time with them.
Post January 31st, 2010, 4:45 pm
Post January 31st, 2010, 4:47 pm
That first pic made me cum.
Panther16? Is that you?
Post January 31st, 2010, 5:52 pm
Perhaps it is!
Post January 31st, 2010, 6:17 pm
Dun dun dun...
- RIP Mitch Hedberg
Post January 31st, 2010, 8:38 pm
How original.
Post January 31st, 2010, 11:20 pm
Post February 1st, 2010, 12:32 am
LOL that picture made me laugh.
Anyway, Flickstah, not only do you need to set the G's correctly, but if you're using N2, you will probably need to use a custom timewarped transition to get the right shaping. I've never tried it, but that's what I would guess. I don't believe that the default transitions will do the trick.
Post February 1st, 2010, 12:56 am
^ ... You just use a multi-zone force? I'm not quite sure what you mean when you say "a custom timewarped transition."
- RIP Mitch Hedberg
Post February 1st, 2010, 2:47 am
^ For extended control you can use timewarping to edit the tension and center of the transition (roll, lateral, and normal forces respectively).
