Board index Roller Coaster Games Hard Hat Area [REL P.4] Grizzly - GCI woodie
Post September 1st, 2010, 10:49 am
How about now ?
(of course I am going to make custom steel beam, because the one that is put now isn't very well correspond...
Post September 1st, 2010, 10:56 am
Points on hand: 3,639.00 Points
only thing I would say now is that the is a lot of weight resting on that one vertical wooden beam you can see at the front of the building, because it has a steel I-beam on the other side of it further up as well as the one you've just put in. hmmmmmph, how about putting steel I-beams going the other way across the building, from side to side rather than front to back?
Post September 1st, 2010, 11:06 am
Post September 1st, 2010, 11:10 am
I don't understand what you're talking about, hyyyper.
And now ?
Post September 1st, 2010, 11:19 am
Points on hand: 850.00 Points
imagine if someone stood up in the car at that time lol
Post September 1st, 2010, 11:24 am
There is 3m between the steel beams and the tracks...
Post September 1st, 2010, 11:25 am
Post September 1st, 2010, 12:38 pm
Points on hand: 4,765.00 Points
Gouldy, the transfer track slides so the beams you marked out wouldn't work. This setup he has currently with the horizontal I beams is nearly identical to what Thunderbird/EK have in real life.
Post September 1st, 2010, 1:22 pm
Sweet,LeFlo,this update made my day(and I had a really bad one)!
Post September 4th, 2010, 7:18 pm
New Update ! I built the supports of the 1st high turn, and of the other turns around it. Here are some screenshots.
Post September 4th, 2010, 7:25 pm
I love your work! Keep doing what you're doing.
Post September 4th, 2010, 7:41 pm
Post September 4th, 2010, 8:08 pm
Your layout is way more complicated that my Jet Corster Discovery coaster.
Post September 5th, 2010, 5:11 am
^ You're making me bored of those comparating posts with your Jet Coasters... This topic is not about Jet Coasters, it's about a GCI. Consider as it is, a Jet Coaster and a GCI are two different types of ride. Plus I don't think my layout is complicated, get out of your Jet Coaster madness...
Otherwise, thank you, LOEA and Slosprint
Post September 5th, 2010, 6:05 am
yah, I know. I was pointing out what would be ideal, and then said that you couldn't do it because of the transfer track, which is when I suggested doing how he has now done it, which seemed most realistic. Now we see that it is exactly how it is done [lol]
Post September 7th, 2010, 7:18 pm
Here they are !
SUPPORTING IS FINISHED !!!! YAY !! [xx(]
Pictures time. [:)]
Post September 7th, 2010, 7:22 pm
Hmmmmmmmmm,pizza!
What have I told you about using your own metaphors?
Post September 7th, 2010, 7:36 pm
Post September 7th, 2010, 9:28 pm
Looking good except I hate the colors. Way too bright.
Post September 7th, 2010, 10:24 pm
Post September 8th, 2010, 2:46 am
Post September 8th, 2010, 7:18 am
It is still very bright for a GCI, but it is less blinding, which is good.
Post September 8th, 2010, 11:51 am
That's pretty much the color of new pine. Check the intern site, very similar to most of the photos there.
Post September 11th, 2010, 7:23 pm
I got a nice update for you : the main part of the station is done ! I actually only made the station itself and the queue... I'll add your-onride-photo stand after leaving the station.
Post September 11th, 2010, 8:11 pm
