Board index Roller Coaster Games No Limits Coaster No Limits problem
No Limits problem
Post December 16th, 2010, 4:32 pm
TRX User avatar
Points on hand: 1,952.00 Points
Hi guys,
I have a strange problem when opening the No Limits simulator, sometimes (just at random) the framerate drops to 3 or 1 and that's it. (Even a map with 50 meters of track had this problem)
Couple of days ago i downloaded the new Nvidia drivers for the graphics card, so i have the latest drivers.
Today i installed No Limits again, and it just didn't solve the problem.
My specs:
- Windows 7 32 bit
- Intel Core 2 Duo CPU E4800 @ 3.00 GHz
- 2048 MB RAM
- DirectX11
- Nvidia Geforce 9600 GT (1758 MB)
I hope that anyone here has a possible solution to this problem!
Bye!
Post December 16th, 2010, 4:45 pm
That happends to me with a track full of 3ds. But not with a plain track. How old is your computer? I've had NL on a computer that is about 7-10 years old. And it worked fine.
Post December 17th, 2010, 6:58 pm
TRX User avatar
About 2 years old.
Post December 18th, 2010, 9:31 pm
Points on hand: 296.00 Points
Bank: 7,431.00 Points
Look at whats running in the back ground. I had to turn off some of the like it would start up virus scans and frame rate would tank.
Post December 18th, 2010, 9:34 pm
Points on hand: 12,024.60 Points
Pretty unprofessional that Ole doesn't have a support link anywhere in the help docs or his site.
Post December 18th, 2010, 10:24 pm
Originally posted by TRX
- 2048 MB RAM
That's your problem
Post December 18th, 2010, 11:02 pm
What's wrong with 2 gigs of ram?
Post December 18th, 2010, 11:11 pm
its 0.2 GB of ram...
Post December 18th, 2010, 11:44 pm
Post December 19th, 2010, 12:36 am
Sounds like you are using a laptop that is using shared memory, the 9600 GT to my knowledge was never produced with more then 1GB of ram. If it is a laptop, I would recommend going into the bios and changing the video ram from 1.5 GB to 64 128 or 256 MB, it sounds like your I/O is getting clogged up from the lack of memory allocation.
Post December 19th, 2010, 6:28 am
Bank: 2,739.00 Points
Dumb question, I know, but "How do you get into the bios on a PC? That is something I have always wanted to know.
Post December 19th, 2010, 10:00 am
Points on hand: 777.00 Points
When your pc starts it say's: enter bios... f10,f11,f12 or del... it depends on the setting, but only enter there if you know something from pc's :) or ask a friend :)
Is it a dell, hp, acer, ...?
Post December 19th, 2010, 2:04 pm
i've never known it to be a problem on windows but when in simulator mode hit 'H' to bring up the help screen then scroll through the pages until you find 'turn off solar flares' then try that.
Post December 19th, 2010, 5:13 pm
Dude, I got a dell, thanks for the info.
Post December 21st, 2010, 9:02 am
TRX User avatar
This is not the problem. One time is still has a framerate of 99, and the next time (30 seconds later) it has suddenly dropped to 1.
It was custom made and not a laptop.
It doesn't work.
Yesterday i opened the editor and build something new and without any problem when i opened it in the simulator, and sometimes the framerate was 2, and the next time (10 seconds later) it was back to normal.
All the computerspecs i gave you was directly copied from the dxdiag command in windows.
Post December 21st, 2010, 3:19 pm
Post December 24th, 2010, 3:27 pm
TRX User avatar
Maybe update your video drivers...?
Already done that.
I do still have this problem, although it works fine most of the time now..
Post December 24th, 2010, 6:38 pm
Have you tried reinstalling nolimits?
(dutch [ Because you live in The Netherlands ])
Heb je de onderdelen zelf gekocht en in elkaar gestoken of heb je in een pc winkel de onderdelen in elkaar laten steken, heb je andere zware games op je pc?
Begon het probleem nadat je de nieuwe drivers hebt ge?????????nstaleert?
Post December 25th, 2010, 3:45 pm
TRX User avatar
Read firstpost ;) Yes i tried it.
Hij is oorspronkelijk in de PC winkel in elkaar gezet, maar ik heb er zelf later een nieuwe videokaart ingezet. RCT3 is op dit moment het zwaarste spel wat ik geinstalleerd heb staan.
Nee. Nu heb ik het wel in mindere mate.
Post December 25th, 2010, 4:53 pm
Whoops didn't see...[sillyme]
rct3 werkt alleen (voor wat ik vind) met de cpu omdat hij maar 1 core ziet.
Ik zou eens vragen aan ole (maker van nolimits) maar ik weet niet of hij zal reageren want hij is druk bezig aan NL2.
Je kan ook eens in compatibiliteitsmodus proberen.
