Board index Roller Coaster Games No Limits Coaster Question about wooden supportwork
Post August 7th, 2003, 11:27 pm
Points on hand: 2,968.00 Points
I am wondering if the track walkways (the yellowish-orange supports in the editor) can be manually created in NL. Or can I only generate them with the auto-support generator. If they can be manually created, how? Thanks.
Post August 8th, 2003, 12:02 am
Points on hand: 4,606.00 Points
yes, there are the three types of wooden supports available for manual construction right next to the other tubes.
Post August 8th, 2003, 1:09 am
Points on hand: 3,503.00 Points
No, you can't create the catwalks by hand.
Buster.
Post August 8th, 2003, 1:50 am
Post August 8th, 2003, 2:09 am
yeah, but he was talking about the catwalks, not the supports
Post August 8th, 2003, 7:32 am
i wondered about that too, but i thing only the suports and not the catwalks
Post August 8th, 2003, 8:45 am
You can: you can put atuo supports on and delete all of them but the catwalks were you want them.
Post August 8th, 2003, 9:26 am
OK thanks for the info guys. I ask because I accidentally deleted the catwalks on one of my segments and wanted to add it back in without generating all new supports. Oh well, maybe a future version will allow you to build them manually.
Post August 8th, 2003, 10:44 am
I looked in to NL and saw that if you make the segment have its own settings, then you can make it so that tha segment will only have catwalks and non-wide supports, which would make it easy to delete the suports you dont want.
