Screamscape source have sent us a bit more information about Phantasialand's new Klugheim project. For starters, apparently the new coaster itself is likely to be named "Taron", as the park has filed for a new trademark to use this name and logo as seen here.
As for the coaster itself... again, the information seems to lead us to think that this is an Intamin made coaster, but with a design that may be more of a mix of Cheetah Hunt at Busch Gardens Tampa and Thirteen at Alton Towers. Our source says that the layout they saw had the coaster leave the station and go through a short dark-ride style indoor section before hitting a launch track and going outside and into a figure-8 style element labeled the "Panorama Curve", which is said to look a lot like the elevated figure-8 element on Cheetah Hunt. From here the train will drop into a series of S-curves before entering a building for another dark ride section that looked to include a 10-meter free-fall drop track element, much like Thirteen. Leaving here, the train appeared to load into a tilt-track style element, much like the one on Escape from Gringotts, dropping the train down and into a second launch track, into an Immelman style inversion, a series of overbanked curves, an into either a corkscrew or zero-g-roll inversion before sliding back into the station one again.
Construction has already begun on theming, footers, and some supports!
