Board index Roller Coaster Games Hard Hat Area {NL2} Calypso - B&M Dive Coaster
Post March 31st, 2015, 4:47 pm
Points on hand: 6,842.00 Points
What's up guys, so when I'm taking a break from my main park projects, I like to throw together "cookie-cutter" layouts that will fit into anyone of my park's line ups... Here, I have Calypso!
I love the look of these trains :P
And I decided to change up the environment!
Calypso is a 262ft. Dive Machine with 4740ft. of track, 3 inversions and a top speed of 83mph!
Let me know what you guys think and keep in mind that supports in some areas (MCBR) are NOT final.
-DechLave T.P Ent.
Post March 31st, 2015, 5:31 pm
Looks like the second vertical drop is not shaped right for a B&M. Unless you are not sticking true to manufacture style.
Post March 31st, 2015, 5:51 pm
^^I spent a lot time on shaping... it's shaped appropriately for a 90 degree drop. B&M doesn't have 90 degree drops after the MCBR.
Post March 31st, 2015, 7:29 pm
Post April 2nd, 2015, 12:00 pm
Love the ride name! :)
Post April 3rd, 2015, 1:06 pm
@Coasterkidmwm - Is this better? I don't know if it's just me but, does the top of the Immelmann on the right of the pic look weird?
Please, keep in mind that supports are not final.
-DechLave T.P Ent.
Post April 3rd, 2015, 1:19 pm
They look much better. My dive loops/immelmans always sucked too, don't worry.
Post April 3rd, 2015, 1:53 pm
My first time doing immelmans for a dive coaster... but thanks! ;)
-DechLave T.P Ent.
Post April 3rd, 2015, 5:06 pm
Sucked? I saw your "Roar" on-ride video and did feel that track was absolutely smooth! Perfectly adjusted! :)
Post April 6th, 2015, 5:41 am
Post April 6th, 2015, 6:18 am
Bank: 122.00 Points
B&M doesn't have 90 degrees drops at all. Not even dive machines first drops are 90??????. Sheikra's is 87??????.
The ride looks realistic. It's something B&M could do. What I don't like that much is the double immelmann combo. I think it's too repetitive. I would have replaced one of them with a dive loop. But it looks pretty anyway. Keep it up!
Post April 6th, 2015, 9:34 am
Post April 6th, 2015, 1:41 pm
Thanks for the feedback! I'll definitely look into your suggestion and try to replace the second immelmann with a dive loop!
P.S it's also news to me that B&Ms don't have 90 degree drops! :shock:
Edit: So, I did some research and it turns out the only B&M dive coaster that has a 90 degree drop is Griffon! :?
-DechLave T.P Ent.
Post April 6th, 2015, 3:50 pm
What's your source on this? Oblivion is 87?????? but the large-scale dive machines (Sheikra, Griffon) are listed as 90?????? by multiple sources, even if they only achieve that steepness for a very short period.
Post April 6th, 2015, 4:00 pm
Bank: 122.00 Points
HZGarfield posted it on NLE as he has a blueprint of the Sheikra clone in China. I supposed Griffon, not being much taller would be the same. Anyway, the difference between 87?????? and 90?????? doesn't change anything.
Post April 6th, 2015, 8:46 pm
^It really doesn't change anything, especially when you're actually on the ride! You MIGHT be able to see it's not a straight 90 degrees if you were to stand back and really look but, the distance you'd have to pan-out too far to actually tell...
BUUUT, for the purposes of MY B&M Dive Coaster, Calypso, the first drop well be 90 degrees and the second (after MCBR) well be like 87-88 degrees...which, IMO is close enough to call "straight down" :D
-DechLave T.P Ent.
Post April 7th, 2015, 12:39 am
Post April 8th, 2015, 7:32 am
