So, it is really nice to see some people being enthusiast for this contest .
As said earlier, we're gonna start this Sunday. We had the results of the roundup already, so now you could prepare yourself to be challenged by the Golden Height Contest.
As promised, we give you the rules today and we'll reveal the building area.
First some rules about the template
- You must build your coaster within the green/yellow area.
- You must build the station inside the yellow area. Storage don't have to be inside the yellow area, you can also make it in the green area.
- Of course, you can't change the mountain setting.
- You can make yourself a custom station or theme your coaster, but you won't get any points for this.
- You cannot design your coaster less then five meters above the road. So it has to be above these 5 meters. To help you, we put a clearance above the road, your train may not touch it with the clearance enveloppe. Supports aren't allowed there either.
Some more rules about your coaster:
- The managers asked us to let you design a coaster with a minimum length of 800 meters/2625 feet.
- You can make only one tunnel, and it has to be shorter then 80m/262ft
- You cannot build this tunnel underneath the entrance road.
- Number of stations + number of storages = number of trains
- Talking about the entrance road: your coaster must be on both sides of the road, so your coaster has to pass the way at least twice.
- We decided to put no maximum length, so Togo, you can design your longest mountain side jet coaster. There is also no maximum height, but keep it realistic.
- There is no capacity requirement, but don't make a coaster with only car with 4 seats
And here is your building area:
We know it is a very hard terrain to make a coaster on it, but somewhere, we have to challenge you.
Next up are some tips made by your judges:
- Make sure the footers don't clip with the terrain.
- There are some flat areas provided in the area, so there you can place most of your footers.
- You can design a wooden terrain coaster or a giga coaster or a dive coaster or ... Choose what you like the most. Multiple entries are allowed!
- Make sure your coaster looks great, has some nice interactions with the road and the terrain.
- O, and one minor thing: make sure your brakes are the correct ones: magnetic breaks can not hold your train in real life, so that is no Block Brake.
- Make your coaster as realistic as possible, you don't have to make an accurate B&M or something like that, you can also be an invented coaster building company, just make sure it looks realistic.
Well, I hope we can have a lot of entries
Sunday, a download link for the template will be placed.
Greetings Pifpoefpaf123 and Ward
PS. Do not hesitate to ask a question about the contest. We're both in the NLC-discord or you can place your question here in the topic or send it with the Messages option or ... We're here to help you making the most beautiful coaster in a mountain setting.
Surprise! https://drive.google.com/file/d/1-atfA0 ... sp=sharing Good luck everyone!
Finished? Send a download link with your name in the parkfile name to goldenheightscontest@gmail.com
