It's going to be a quick shuttle coaster. But it wasn't as quick as I hoped for it to be. I am having slight problems with the twisting tophat. (heartlined) The main part of the heartline is as smooth as I can get it (with bumps of course), while the lead in and the leand out needs some work. Basicaly, it's like a modified reverser freefall, modified to greater speeds, (about 124mph) and higher heights (about 490ft), and it's vertical spike is a heartlined 450 degree twist. It's lauch is overspeeded actually, and would launch it off the tower if it wasn't the brakes up there stopping it. After that, it falls down, and gets braked as usual as it goes back to the station.
BTW, I have 2 names in though for it. Sargent racer and The Lighthouse. The Lighthouse sounds alot better and the first one sounds just gay, so I guess it may be renamed, just ned some thoughts. [blah]
Edit: Any posts? Arg, I try too many projects at a time.
