OK, I have been working on a twisted steel coaster.
I have completed the track,and supports. Looks great.
Spent hours on making it as smooth as possible. Even used the construction kit.Made it ride GREAT!
Then, I put terreforming,have created a castle theme with 3-d objects made with object creator,has scenery, Everything.
My problem is know when I ride the coaster, Its now bumpy in alot of areas. I tried to correct it and still the same.
Do's adding alot of 3-d ojects, tereforming, and landscaping effect the coaster that much?
and if so, can it be corrected easy?
If you can help, I would appreciate it.
