Board index ‹ Roller Coaster Games ‹ No Limits Coaster ‹ Brakes problem
Brakes problem
Post April 6th, 2012, 3:57 pm
Points on hand: 829.00 Points
I am working an a track, but the train gets stuck at the final brake run, no matter what i do.
i tried to use friction wheels and changed all the settings.
Does anyone knows this problem??
Post April 6th, 2012, 4:04 pm
What are all of the settings on the brake run? (a screenshot would be perfect)
Post April 6th, 2012, 4:32 pm
The brake run is tilted downwards so gravity is not a problem. it's followed by a empty Station Segment
Post April 6th, 2012, 4:45 pm
Points on hand: 6,904.00 Points
on my laptop u cant have the speed limit higher than the transport device speed. if u have the speed limit at 5 and the transport speed at 10 they fight back and forth and don't let the car move. this is just on my laptop i don't know if anyone else's does this. i would recommend changing the speed limit to match the transport device speed.
Hope that helped!
Post April 6th, 2012, 4:46 pm
Have the speed limit higher than the Hysteresis. Pretty sure that would do it.
edit: ^I'm pretty sure that just makes the brakes slow down the train while the transport speeds it up, making it sort of pump, but it should still work with that situation.
Post April 6th, 2012, 4:51 pm
ok:P the hysteresis did it:P thank you
Post April 6th, 2012, 5:37 pm
RideWarriorNation User avatar
What type of coaster is it?
Post April 6th, 2012, 5:44 pm
bobsled, I'm trying to make a recreation of an E-motion coaster:P the track oaf the bobsled looks the most like the emotion track, to bad NL doesn't has the correct train type
Post April 6th, 2012, 5:57 pm
Points on hand: 1,137.00 Points
Your settings are kinda circular:
Trans device speed is 10;
-Train will accelerate to 10
Speed limit + Hysterisis = 10;
-It will start breaking when speed reach 10
Speed limit - Hysterisis = 0;
-Break device makes it reach 0.
Now it repeat
Post April 7th, 2012, 7:33 am
transport is already off, i had it turned on when i was testing what the problem was.
Hysterisis is at 1 now and now it works. :D
