Board index ‹ Roller Coaster Games ‹ No Limits Coaster ‹ NoLimits Track Packager Problem
Post June 30th, 2008, 12:00 am
yoshifreak Premium Member
Points on hand: 241.00 Points
Ok so here is my problem:
Recently my hard drive crashed and I had a backup copy of No Limits. I then copied the entire NoLimits folder to where it used to be in my PC under program files. But then, when I installed the track packager it says, "Nolimits root folder not found", so I browsed and set my NoLimits root folder to "NoLimits Coaster V1.6" and it will work fine, but once I close and re-open the program, it no longer recognizes the root folder, and I have to select it every time I close and open the track packager. Any help in sorting this issue out would be appreciated, thank you.
Post June 30th, 2008, 12:08 am
You need to reinstall it to set the settings in the registry.
Copy and paste will not solve this problem.
Post June 30th, 2008, 12:18 am
Ok I'll try reinstalling it. Thanks.
