Board index Roller Coaster Games Hard Hat Area Arrow/Vekoma inspired
Post January 30th, 2012, 10:01 pm
I can always drop the non-inverted piece, too.
Edit: Roadrunner, do you have any good pics of a butterfly loop? Or do you have one you can send me?
Post January 31st, 2012, 12:08 am
Fixed.
Post January 31st, 2012, 1:07 am
Points on hand: 172.00 Points
^There are a few of Goudrix's here:
http://rcdb.com/753.htm?p=0
And a couple of Ninja's here:
http://rcdb.com/40.htm?p=0
They pretty much look really weird and seem to ride terrible, but that's just based on videos.
Post January 31st, 2012, 1:31 am
looks kind of like double bat-wing, I've experimented with something similar
Post January 31st, 2012, 8:54 am
Almost looks like a modified cobra roll
Post January 31st, 2012, 5:15 pm
Here, I can send you a butterfly on friday
YES!
Post January 31st, 2012, 10:44 pm
I'll try to make one and I'll get back to you if I still need one.
Edit: While trying to make a butterfly loop, I made this instead.
Edit again:
Layout version 3
Post February 1st, 2012, 12:46 am
I like the inversion(s), but the turn after the MCBBR looks very egg shaped rather than circular
Post February 1st, 2012, 1:06 am
Well, I'm having some issues with that turn. I need it to come back to point south before heading into the corks at the bottom of that hill, when I smoothed the transition from the bottom of the hill and the beginning of the cork, it turned the track and caused that egg shape.
Post February 1st, 2012, 2:10 am
Blade User avatar
Points on hand: 6,325.00 Points
Here?????????s a good picture of a butterfly.
Post February 1st, 2012, 6:29 pm
I like that thing you made. I would vote for that or the Butterfly. But it's up to you. :)
YES!
Post February 1st, 2012, 6:42 pm
Perhaps I could fix some of the issues I'm having with my current configuration if my first inversion pointed in a different direction. Since I can't seem to figure out how to make a butterfly, maybe someone will help? Once I get two prototypes, I'll hire on a tester or two.
Post February 1st, 2012, 6:57 pm
I will gladly test and give you my Butterfly, just if you use it please say you got it from me :)
YES!
Post February 1st, 2012, 6:58 pm
Of course
Post February 1st, 2012, 7:11 pm
Okay, it's looking great so far. Good luck, will there be theming and/or que/.3ds? Also I will soon be making my own Arrow-Hyper/Looper but that's another story.
YES!
Post February 1st, 2012, 7:19 pm
Once I have a layout that I'm happy with, I'll add in the theme and stuff. For now, we build!
Post February 1st, 2012, 7:23 pm
Yes, I agree but at this point I just wondered if you had considered a theme. You are pretty far into the build.
YES!
Post February 1st, 2012, 8:01 pm
I think I'm going to stick with a generic theme park. Or I could re-make a certain part of my "home park" - Darien Lake.
Post February 1st, 2012, 8:28 pm
Remember to make the incredibly stupid twist part in the butterfly lol
Post February 1st, 2012, 9:30 pm
I have the butterfly...perfect in all it's glory or lack thereof. You will be pleased ;) Also if you need any .3ds that might have been in my Rex of ShockWave you can use them again as long as you give credit :)
YES!
Post February 1st, 2012, 10:46 pm
I have some .3ds that I'm going to use along with some custom objects.
Post February 1st, 2012, 11:06 pm
Points on hand: 943.00 Points
That's way better than any butterfly roll...you could call it a "reverse double butterfly" as Arrow calls its batwings "reverse double boomerangs..."
Post February 2nd, 2012, 12:08 am
I thought it was pretty cool, too. But the orientation of it forces me to modify other parts of the coaster, which is causing problems.
Post February 2nd, 2012, 7:54 am
Any way, you want it man. I will send you the Butterfly and you can use or or not. Also I usually make a generic theme park setting as well. But .3ds always enhances the ride so I would always take the time to put it in. I can't wait to see the final product. :) Custom Cartexture?
YES!
Post February 2nd, 2012, 9:19 am
I'm probably going to customize everything
