Board index ‹ Roller Coaster Games ‹ No Limits Coaster ‹ REALLY annoying problem w/ Track Packager
Post September 9th, 2008, 4:56 pm
Points on hand: 2,044.00 Points
Okay, so i just moved back to MI w/ my dad, and i'm trying to download the NL Track Packager. I found a few links to download it, and everything works fine at first. But once i finally install it, i attempt to run the program, and it says "WARNING - cannot locate No Limits Root Folder", and then says "No Limits root folder invalid". It's really p*****g me off and i can't download half the coasters i want, and i have no idea what to do. Any help please???
"If that boy billionaire thinks he can shut me up, he should stick his head in a can of paint." - Myron Cope R.I.P.
Post September 9th, 2008, 5:13 pm
errr, i had this problem and i think i fixed it by only using track packages that were in the same folder as the packager as far as I am aware
Post September 9th, 2008, 5:57 pm
yoshifreak Premium Member
Points on hand: 241.00 Points
I had this same problem; I ended up having to reinstall NoLimits. Remember to backup all your track files, objects etc. before you do it too.
See Here: http://coastercrazy.com/forum/topic.asp?TOPIC_ID=18030
Post September 9th, 2008, 6:04 pm
before you rinstall you might want to move the original (zip?)file to the no limits folder in your program files and extract it there.. i seem to remember having to do that to make it work
Post September 9th, 2008, 6:17 pm
When the "WARNING - cannot locate No Limits Root Folder" pops up, do you navigate to the No Limits folder?
Post September 9th, 2008, 7:16 pm
Points on hand: 62.00 Points
well... what I did was whenever that happened, I took the track package out of one of the folders in my comp and reloaded it and it worked fine.
