Board index Roller Coaster Games Hard Hat Area Laser under construction!
Post July 21st, 2005, 1:41 pm
I don't know exactly what's happened with my previous project but Deep Impact is lost![confused].I'm sorry about that but I began a new Intamin rocket coaster called LASER:
Here first photos of the station:
from the fall tower..........
and the launch.......
Post July 21st, 2005, 1:45 pm
Points on hand: 6,575.00 Points
awsome 3D's, what do you use?
Post July 21st, 2005, 2:27 pm
Object Creator.......
Post July 21st, 2005, 2:31 pm
Be sure the polys you can't see are removed (optimization).
Bu the 3ds are good, even better considering that you used OC. (I find it to be too limiting)
Oh yeah, where are the lasers? [:)]
Post July 21st, 2005, 2:37 pm
rob User avatar
Points on hand: 3,083.00 Points
wow looks like an awesome ride with nice scenery, is the fall tower just part of the scenery right? The ride doesnt accully go down it or anything?
Post July 21st, 2005, 3:08 pm
Points on hand: 7,382.00 Points
Looks great!!
Are you going to have inversions or will this be a terrain rocket?
As always, I look forward to your finished ride. If you need a test dummy, please accept my application.
Post July 21st, 2005, 4:51 pm
Here's the main layout with 5 inversions.Ride is short but intense........
When I finish supports I'll send you the file pdonahue[;)]
Post July 22nd, 2005, 2:34 am
that's insane....,
can i be a crash-test dummy too?
Post July 22nd, 2005, 8:02 am
Sure............
Post July 22nd, 2005, 10:03 am
I changed the beginning of the layout adding an inner top hat....now the inverting elements are:top hat,cobra-roll,loop,sidewinder,diving-loop,interlocking corkscrews.....now start supports work!
Here a photo:
Post July 22nd, 2005, 6:47 pm
Points on hand: 905.00 Points
Those supports look very fragile right now. They'd better get better. As of right now it looks as if a misdirected fart could knock this thing over.
Post July 22nd, 2005, 11:43 pm
Oh sure Iron Man.....it was only the beginning....however:any original ideas for different supports?I would like to give a total new touch to it!But it's really hardddddd[;)]
Post July 23rd, 2005, 2:16 am
Points on hand: 2,200.00 Points
if you dont mind spending alot of work you could do something based around curved or bent supports, kindof like this(H is vertical track, = are connectors, rest is supports)
|\-|=H
|O)| H
|/-|=H
just a thought
Post July 23rd, 2005, 2:46 am
???? lol, thats a really confusing chart there.
Post July 23rd, 2005, 5:43 am
|\-|=H
|O)| H
|/-|=H
just a thought
a screenie would help a lot, ya know?
Post July 23rd, 2005, 2:20 pm
I didn't understand too[flush]but I am always in time to change them...now I'm building them on the model of Xcelerator at KBF...due to the similar height of the top hat.
Here a photo:
Post July 23rd, 2005, 5:05 pm
no heartlining? :(
Post July 23rd, 2005, 7:47 pm
heres a picture of that chart, but keep in mind this is just a quick little thing, and no intention of using this design knowing it is insufficient.
Post July 25th, 2005, 2:48 pm
Fornication I'm not so good in heartlining[:(]
I finished supports on the top-hat and the loop....
Post July 25th, 2005, 8:47 pm
This is the launch tribune from which you can see the whole ride:
Post July 26th, 2005, 4:51 am
have you tried using the AHG?
Post July 26th, 2005, 8:28 am
Yes but there is a constant horrible pumping.I think I was doing something wrong so I decided to give up!
Post July 26th, 2005, 12:13 pm
Cobra-roll supports...........
Post July 27th, 2005, 12:50 pm
i'd make some more attactment form the supports to the cobra, a bit like the overbank of MF, it looks like there are large supports only attacthed at one point, but it's your coaster, you decide
Post July 28th, 2005, 8:37 am
Laser is close to grand opening.Here a funny visual effect in the flatspins!
If someone is interested in testing it I send the file while I'm finishing the scenery....from tomorrow!!!!!!![;)]
