Board index ‹ Roller Coaster Games ‹ Roller Coaster Tycoon 1, 2 & 3 ‹ Help with track merging
Discuss anything related to the Roller Coaster Tycoon 1, 2 and 3.
Post October 9th, 2004, 7:26 pm
Points on hand: 2,671.00 Points
Can someone help i dont get it. Thanks
Post October 9th, 2004, 7:30 pm
What kind of problem are you having, man?
Post October 9th, 2004, 7:56 pm
i dont know how to work it the directions are to complicated, i tried to merge a lift hill and turn and drop and cant
Post October 9th, 2004, 8:04 pm
Brtnboarder495 Premium Member
Points on hand: 5,372.00 Points
We need more description and facts.
Post October 9th, 2004, 8:08 pm
I made a sideways lift on a cork and a turn, i want to connect a hyper coaster drop to the cork turn but cant, i like the big hyper drop instead of the small cork drop. Can someone explain the directions and make them clearer for me?
Post October 10th, 2004, 11:21 am
I am not sure I am getting what you are saying, but I may have an idea of it. (I assume this is for NL.) Try this: Try saving the piece you created as an element and then after clicking on the last vertice of your coaster, go to; File -> Insert Element and select the portion you saved to be added. That should put the two pieces together.
Post October 12th, 2004, 3:20 pm
Points on hand: 4,565.00 Points
This is the RCT 1, 2, and 3 section!!
Post October 12th, 2004, 6:13 pm
GRIM.657 User avatar
Points on hand: 5,299.00 Points
G-force, are you using rct1 0r 2, SoB or 8ct?
and give a better description of what your trying to merge.
Post October 16th, 2004, 6:56 pm
What is easier to use on rct2 sob or 8 cars per trainer? how do you use son of beast?
Return to Roller Coaster Tycoon 1, 2 & 3
