Board index Public Relations Contests 2010 NLT - Round 1
2010 NLT - Round 1
Post February 7th, 2010, 4:41 pm
Yeah it turned out to be too much for mine. I hit like -1.4. Eugh...
Just keep scrolling...
Post February 7th, 2010, 6:00 pm
"will we be marked down if we use premade supports on the very low sections of track?"
You should be, as premade supports are very unrealistic.
Post February 7th, 2010, 7:25 pm
^Mine was at about zero g's before AHG, so it turned out perfect.
Post February 8th, 2010, 5:58 am
If the supports are unrealistic or not strong enough you will be marked down. And I haven't seen many occaisons where prefabs actually look realistic.
B&M hypers, in this case, have on the low sections usually the |\ shape and on the bottom of the drops the track is usually directly connected to the footer.
Post February 8th, 2010, 6:11 am
Points on hand: 290.00 Points
"Usually directly connected to the footer" - this is quite an assumption hyyyper.
This doesn't happen on Diamondback, Intimindator or Goliath SFOG; just to name a few.
Post February 8th, 2010, 10:14 am
^It happens on Diamondback, Behemoth, Apollo's Chariot, Raging Bull and Goliath as far as I can from pictures, so perhaps there are more.
But you are right, 'usually' is a big word. But it happens from time to time.
http://rcdb.com/m/4253.htm?p=22853
http://www.rcdb.com/m/4005.htm?p=21609
http://rcdb.com/m/531.htm?p=871
http://rcdb.com/m/535.htm?p=473
http://rcdb.com/m/3290.htm?p=15582
Post February 8th, 2010, 12:28 pm
I misread your "drops" to mean 1st drop.
Post February 8th, 2010, 12:29 pm
Points on hand: 332.00 Points
I could kick my own ass for not having had enough posts for participation. Should've spammed before the entry deadline [xx(]
Post February 8th, 2010, 12:31 pm
I just put in the MCBR and i already have 3500 feet of track. Ooops.
Post February 8th, 2010, 4:34 pm
Trackwork 95% complete. A few banking issues to smooth out.
Post February 8th, 2010, 4:38 pm
Points on hand: 196.00 Points
I'm 100% done with the trackwork and about 25% with the supportwork.
Go me!
Post February 8th, 2010, 5:09 pm
just thought id make it clear. looks from what you said its a no
the bottom ones are prefab but the rest are custom so thats what i ment. i just find if you use custom so close to the ground they look rubbish
Making screams come true
Post February 8th, 2010, 5:33 pm
^I really can't tell from just that. If the drop happens to be the first drop then the tube has to be very wide. If it's the final bunny hop, the prefab support might be thick enough.
If it looks as if the support can handle the strains of a train speeding trough, I don't see any reason to deduce points.
Post February 8th, 2010, 5:40 pm
Since NL doesn't have the track to support connections (without doing a painful amount of 3ds), I just use prefab supports when the track is connected directly to the footer.
Post February 8th, 2010, 5:46 pm
Make sure you put footers on the prefabs.
Post February 8th, 2010, 6:56 pm
Points on hand: 3,978.00 Points
^what?
Post February 8th, 2010, 6:58 pm
To make it more realistic looking.
Post February 8th, 2010, 7:24 pm
the footer is automatically placed, how do you not know that, you use prefabs...
Post February 8th, 2010, 8:03 pm
Points on hand: 232.00 Points
Rofl.
Post February 8th, 2010, 8:18 pm
thanks hyyyper that cleared things up. its just going to be tight a finish with the supports lol
Post February 9th, 2010, 1:20 am
Hey, so I think i finished everything too fast....I'm gonna go back and make sure everything's good! I'm still debating 3ds, though...hrmm....
Post February 9th, 2010, 1:54 pm
Supports for the first two hills done.... hopefully I'll be able to finish in time.
Post February 9th, 2010, 2:49 pm
I have my layout finished, but I still need to make some adjustments for smoothing, and I might have an e-stop problem.
Post February 9th, 2010, 3:24 pm
i got my e-stop well sorted.
may have some final track ajustments now and about 45% of the supports done
Post February 9th, 2010, 3:25 pm
My e-stop is fine, it's just the tunnel test I'm worried about.
