Board index ‹ Roller Coaster Games ‹ No Limits Coaster ‹ Problem making objects with OC and inserting them
I am trying to make a simple floor in the shape of a rectangle.
I am trying to make it so that I don't have to mess with the scale of the object when i insert it into the editor(NL).
So, I built a rectangle, inserted and found that it was a bit too 'short'. I then lengthened it but when I inserted this new object, the width had 'shrunk'.
Here is a screenshot of what I mean. Object one on the left, and then the one on the right is the one I tried to lengthen, only to have the width get smaller.
http://img301.imageshack.us/img301/3584/diagram3od.jpg
Also, one of my textures is showing up wierd in the simulator. At most angle it shows up as a yellow haze and the actual texture is only visible at certain angles. And the part that does look like the actual texture is blurry.....
http://img301.imageshack.us/img301/6340/blurry3ab.jpg
Any help?
Post July 7th, 2005, 3:42 am
nevermind, got them both solved
Post July 7th, 2005, 4:17 am
well I think the bluring one was because you had overlapping brushes.
Post July 7th, 2005, 9:52 pm
And low res textures look blurry because of the texture filtering.
Do make efforts to prevent overlapping brushes, it looks just terrible. And be sure to optimize.
