Board index ‹ Roller Coaster Games ‹ No Limits Coaster ‹ Problem: track is kinking on it's own accord
Points on hand: 1,764.00 Points
When I try to create a steeply banked turn at the top of a hill (such as in Nitro's second hill), It seems no limits continuously insists on "kinking" the track, where I see the heartline perform a lateral fluctuation achieving nothing more than a severe pump. For whatever reason, nothing I attempt seems to make it go away. Swapping around vertexes is no help, it simply loosens or tightens the kink, which I do not want there at all. It seems like a section of track is fluctuating from 0 bank to a slight bank then immediately back to 0.
After doing a little playing around with "make straight" commands, to straighten the track a little, I pressed "smooth", and this happened:
AHG was used once for the initial turnaround, that's it. I'm trying to get to a point where I can heartline this next curve, but because of this predicament...[:(!]
Is this AHG acting up or is it something different?
Edit: It seems this happens when I try to start a bank on an incline.
Post April 21st, 2009, 4:38 am
Points on hand: 829.00 Points
Try to turn "Continuous roll" off
Might help
Post April 21st, 2009, 5:18 am
That did help.
Sometimes, I hate Occam's Razor.[V]
Post April 21st, 2009, 9:12 am
Points on hand: 59.00 Points
Your vertices are too long. Click on the vertexes and drag their "lines" in. You just have too much track so it's bending it to fit it in.
Hopefully that works.
^the message is up there^
Post April 21st, 2009, 10:05 am
Oh yeah, and use Ctrl and G. Built in smoother, however you may need to tweak the track and use Gtrl and G to get it perfect.
Post April 21st, 2009, 11:34 am
yeah, i lose count (not that i DO count) of how many times i press ctrl+G in one session
