Board index ‹ Roller Coaster Games ‹ Hard Hat Area ‹ [NL2] Monolith - Kings Adventure
just a suggestion, but you probably need more reinforcing beams between the two spines
Bank: 1,372.00 Points
^I'm planning to, I was messing around with the construction kit last night and that's what I ended up getting, I'm going to mess around a bit more tonight to see if I can get them better looking and add in the beams between the 2 spines.
I sense major I305 inspiration in here :P
Points on hand: 32.00 Points
Very well could be
KA released 2 more pictures today:
Looks like they are finally starting with the theming of the surrounding area. It looks fairly simple, but I think it could work.
The trains have also arrived on site, so hopefully testing should start soon and we can finally see what sort of punch this ride will pack.
Post November 10th, 2014, 8:02 pm
Looks sick! Can't wait until testing ;)
Post November 10th, 2014, 8:13 pm
Points on hand: 907.00 Points
This looks amazing, and your presentation is 10/10. How did you get double spine? WTH is the construction kit?
Post November 10th, 2014, 8:20 pm
^The NL construction kit, it essentially allows you to make your own tracks, among other things. It's complicated at first, but it can be pretty powerful when you get to know hoe to use it. Sadly though, it isn't compatible with NL2, only NL1, FVD and Newton.
Post November 10th, 2014, 8:43 pm
Oh neat. So if you import something to NL2 that you made it transfers?
Post November 11th, 2014, 8:51 am
He can go through later if he has to and add little beams to make the double spine connect better. It would probably be easy to see in the editor if the extra spine is a 3D object. Also very nice custom station. I've only successfully made variants of the same concrete block in my life lol.
Post November 12th, 2014, 3:32 pm
Bank: 1,275.00 Points
Does a download for the construction kit even exist anymore? I can't find a download anywhere. Awesome work on the double spine!
Post November 13th, 2014, 5:54 am
Almost all of the NL Tools can be downloaded HERE:
http://lucasbosch.de/nolimits-tools/
EDIT: Also, was this track made with newton2 or FVD++?
Projektion wrote:
That picture fooled my boss into asking "Where's that one?" as he walked behind me. At a glance this looks like a photograph of an actual coaster being topped off. Kudos.
Post November 13th, 2014, 9:45 am
That's a great indicator of success then Gouldy lol.
Post November 13th, 2014, 10:40 am
too releastic my mind has been blown away with this
Post November 13th, 2014, 10:43 am
That's a great indicator of being caught procrastinating too :P
Looks great as always Projektion!
Post November 13th, 2014, 12:44 pm
^ I wad gonna say, his boss is very cool if he's ok with someone on here at work >< then again, that's usually where I post from :p
Post November 13th, 2014, 5:04 pm
lol. caught yourself
Post November 13th, 2014, 5:19 pm
Finish this nao pl0x.
Post November 21st, 2014, 10:45 am
Amazing!
Post November 24th, 2014, 8:51 am
JAMMY User avatar
Event Coordinator
Event Coordinator
The passion and drive you have for your projects Projektion is great. This is certainly shaping up to be a great coaster and I think it perfectly shows off how beautiful and realistic NL2 can be.
Can't wait for the release! :)
Steam: JAMMYD777
https://twitter.com/JAMMYD778
Post November 24th, 2014, 9:00 am
^ me too!
Post November 24th, 2014, 9:08 am
Thanks for the comments, I'm currently a little burnt out from working on Monolith at the moment (which explains the lack of updates). I recently made Poseidon in hopes it would start getting the creative juices flowing again, so hopefully I should be able to start some more work on the surrounding area soon as I'm currently brain storming with what I can do with it.
Post November 24th, 2014, 2:04 pm
^ NP, take your time, the longer you take, the better it will be in the end!
Post November 26th, 2014, 9:06 am
I had to do the same thing with LiveWire, made a few start up projects just to get some motivation :D
