Board index ‹ Roller Coaster Games ‹ No Limits Coaster ‹ Auto-Flanger Problem....
Post August 31st, 2005, 12:55 pm
Ok, I 'flanged' one of my tracks with Buster's autoflanger, but it made ALOT of the ground into water.
I loaded the track into the terraformer and none of that water is there and all the land appears to be above water?
Is there anyway that I can flange my track without adjusting the ground after, so that all the flanges and supports don't get out of wack?
Would loading the track into a pre 1.5 NL version, saving it and then 'flanging' it work?
Post August 31st, 2005, 1:31 pm
i might have a solution, not a fix for the problem,
if you have water in your landscape, make them 3ds and then make the water texture in the NL-landscape menu the same as your terrain
or
after adding the flanges, highen the ground with 0.01 meters untill the water disappears, your flanges wont be in the perfect middle anymore, but they'll be fine
Post August 31st, 2005, 1:35 pm
That second option might work.
There is no way I'm doing first one though. All of my supports would need to be redone :(
Post August 31st, 2005, 1:45 pm
Points on hand: 7,382.00 Points
I've also had the same problem. I tried the second solution and it worked OK for me.
[:D]
Post August 31st, 2005, 2:12 pm
Awesome, it worked! I just raised the land by .001 and it didn't have any noticable effect on the flanges [:D]
Post August 31st, 2005, 2:23 pm
you see, i can be usefull sometimes
Post August 31st, 2005, 3:03 pm
yeah, now get working on that quiz [lol][lol]
