Board index ‹ Roller Coaster Games ‹ No Limits Coaster ‹ help help help!!!! EMERGENCY!
Post February 11th, 2008, 12:08 am
Points on hand: 1,617.00 Points
how do you make good holding breaks for launches, for example, on rockin roller coaster, you go around a corner then the breaks hold you for a few seconds before the launch..
can anyone help me?
Post February 11th, 2008, 12:31 am
yes i can.
1. double click the brakesegment.
2. click "complete stop" (top left corner)
3. under, there's a box for "stop-wait time"
4. choose how long you want the brakes to hold the train
(p.s: you'll also have to enable transport device for that brakesegment too)[:D]
thats basically it [;)]
Post February 11th, 2008, 12:41 am
Oh, I thought by the title you were being approached by CoasterkidMWM.
Post February 11th, 2008, 12:45 am
haha [:D][lol]
Post February 11th, 2008, 12:46 am
yea i got that, but it makes the train do this weird lurch thing, i cant make it stop doing that.
Post February 11th, 2008, 12:48 am
ok, well i dont know what you mean by that... maybe its a glitch??? [confused]
...because ive never had any problems like that *knock on wood*
Post February 11th, 2008, 1:00 am
Try this...
-Double click brake segment
-click complete stop
-enter time
-make sure that enable transport device is on
-choose a speed which is much slower than launch (i.e. Transport- 5mph Launch 60mph)
-Select launch
-Enter your launch g force (equal to your actual launch)
-Make sure your trigger is set to Front car
-Move the arrow close to the right line but not to close (seg end)
-Hit OK
Try that...
Post February 11th, 2008, 1:05 am
Points on hand: 5,840.00 Points
EDIT: ^basically that
I'm not sure if this is what you mean but here's my brake/launch method that may help:
First do everything that coasterking said, which you already have down apparently.
Then you need to move the position that the train stops at further up along the brakes. You need the train to stop in such a way that the very front of the train is on the launch segment. There's a slider in the Brakes Properties that adjusts the position. This way the launch will start as soon as the brakes release. If you just have the train do a complete stop, it'll stop and then slowly move forward into the launch section.
If the train gets pulled off the brakes, move the position back until it works as desired.
Hope that helps!
Post February 11th, 2008, 1:07 am
Right click in my pants biznatch
Post February 11th, 2008, 1:22 am
Complete stop only works in continuous circuit mode. That should fix all your problems.
Post February 11th, 2008, 2:49 am
coolbeans326 User avatar
nerdslapped! haha! High FivE!
Post February 11th, 2008, 8:10 am
Points on hand: 290.00 Points
Yer, guitarplayer said it for me. Just complete the circuit and it'll be fine.
Post February 13th, 2008, 7:22 pm
it wasn't working for me either, it kept stopping then instantly going again, its cause i was on shuttle mode to make sure the coaster would get round the track, i pressed connect, put continuous circuit on and BAM!(yes it did that) the coaster worked the way i wanted instantly
Post February 13th, 2008, 7:32 pm
Bam! BAM! BAM BAM BAM BA BA BA BAM!
Post February 13th, 2008, 8:55 pm
Bam bam bam ba ba blah bubble blah bargel BLAHHHHHHHHH!!!!!!!
haha, spased out.
lol
Post February 14th, 2008, 8:58 am
spas attack... BAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAM BAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAM BAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAM BAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAM BAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAM BAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAM BAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAMBAM
BAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post February 14th, 2008, 12:33 pm
ban tha foo!
Post February 14th, 2008, 1:04 pm
lmao
Post February 15th, 2008, 4:10 pm
yea that did fix it. thanks guys.
