Board index ‹ Roller Coaster Games ‹ NoLimits Coaster 2 ‹ Lights, lights, lights...
Post January 13th, 2014, 9:45 pm
Points on hand: 3,816.00 Points
I've been messing with the lighting objects included with NL. I wanted to tweak the "Spot Light White" object so that I can have something a little more intense, and different colored lights. I'm a sucker for lighting and making things look dramatic at night. I'm not sure where to go with this but decided to do some digging.
I opened the Spot Light White.nl2sco with Notepad and saw some values that can be modified such as color and intensity. I saved the nl2.sco file in my park folder (I saw that nothing should be changed within the main installation folder) but am not seeing that object when I try to add it to my park through the NL2 program. Am I even going at this the right way?
Mean time, I'm going to continue messing with this.
Thrills by the Bay - Your #1 News Source for Bay Area Parks!
http://thrillsbythebay.blogspot.com
Post January 13th, 2014, 10:09 pm
Bank: 2,500.00 Points
is there a way to toggle day/night in simulator?
Plantoris
Post January 13th, 2014, 10:26 pm
I'm not sure if there's another way of doing this but I went into this to make it evening...
373.28 KB
With the above noted, this is when I decided to mess with spot lights but they seem a bit weak.
372.3 KB
Post January 13th, 2014, 10:34 pm
A.S.C. User avatar
Points on hand: 59.00 Points
Bank: 1,276.00 Points
The day/night cycle is an hour long, wait in the simulator for about 25 minutes and you should notice the sun start to set.
Post January 13th, 2014, 11:49 pm
You can change the cycle to whatever you want.
I changed it to 5 minutes and within 2.5 minutes it was night.
Post January 14th, 2014, 12:16 am
Points on hand: 2,891.00 Points
I've crossed out your mistake. Don't open the file in Notepad. Instead, open it in the NL2SCO Editor in the Scenery tab and then "Save As" to your own park's folder. Then you'll have a copy of the file with proper file references, which is what you're missing. You can open that new scenery object in the NL2SCO Editor, go to the Lights tab, and modify the properties of the light to whatever intensity or color you wish.
Post January 14th, 2014, 12:35 am
Awesome, thanks!
384.27 KB
Multiple lights & blending...can make a coaster pretty dramatic at night!
453.08 KB
Which this now raises my next question: Is it possible to turn one of these lights into strobes or something that cycles colors?
Post January 14th, 2014, 12:52 am
Pretty! :D
Post January 14th, 2014, 4:01 am
^^ Very pretty!
Rarwh
Post January 14th, 2014, 10:13 am
Points on hand: 374.00 Points
In the editor, Park tab, Environment button, you can set the simulator time based on a 24 hour clock.
Post January 14th, 2014, 2:04 pm
Bank: 3,034.00 Points
As a permanent time of day that doesn't change?
Post January 14th, 2014, 2:21 pm
Gosh darn this looks nice. Hey phyter... can we have a mac version right now please? [:D]
Post January 14th, 2014, 2:24 pm
It's for that park only, but it's saved as part of the park and doesn't change back to the defualt.
EDIT: I should elaborate. That changes the default starting time for that park. Set it to 22:00 and that park will always start at 10:00 PM. Time will still pass in simulator mode and the Day/Night cycle will still run, but it will always start at 22:00 (10:00 PM).
Post January 14th, 2014, 7:53 pm
Points on hand: 457.00 Points
Wow! That's awesome.. How come these files to objects and elements to Crazycoaster ??
Post January 24th, 2014, 9:23 pm
How do you get the light far but with little only a little cone?
EDIT: NVM, figured it out
