Board index Theme Park Discussions Theme Park Trip Reports My KINGDA KA Model! PLEASE REPLY
Post November 9th, 2005, 10:05 pm
Points on hand: 2,184.00 Points
Ok so me and one of my friends are going to make a scale working KK model and we had some ideas but I was wondering if anybody else had some decent ideas to make it out of ( i would like it if someone was an engineer but anyone can post a reply :)!
PLEASE REPLY
Post November 9th, 2005, 10:07 pm
Points on hand: 2,931.00 Points
use knex
Post November 9th, 2005, 10:11 pm
i am using plastic for the trains copper for the track a motor and guitar strings for the launch system but i and not sure about the brake pads and breaking system
Post November 9th, 2005, 10:19 pm
Points on hand: 3,649.00 Points
ooohh, guitar strings good idea, sounds...advanced
Post November 9th, 2005, 10:23 pm
thanks bryan
Post November 9th, 2005, 10:45 pm
how'd you know my name?! jk, profile I know
Post November 9th, 2005, 10:56 pm
Points on hand: 5,058.00 Points
brakes? maybe teflon or something that doesn't move? :S (could get worn down though). As for the copper tracks, I think aluminum is easier to work with. Just curious, specifically why did you pick copper? Do you have ready access to some or something?
Post November 9th, 2005, 11:00 pm
^I don't think you can buy aluminum track material at a place like home depot. It's also harder to connect especially by weld because of aluminum's oxidation rate.
Post November 9th, 2005, 11:02 pm
Points on hand: 1,977.00 Points
You must be good because I tried to make a HUSS top-Spin a few years ago, without the model kit and it was a disaster. The electrical part was going to be a nightmare for me too. You can do it. How high are you going to make it?
Post November 9th, 2005, 11:08 pm
umm I wouldn't suggest guitar strings for the launch unless they're very broken in because they aren't exactly the most flexible thing ever.
As far as track, I dunno, I'd say unless you have a good way to shape it smoothly, don't use copper. Aluminum is way more ... shapeable if you will.
Post November 9th, 2005, 11:24 pm
Points on hand: 3,540.00 Points
why is this topic posted on the trip report forum?
Post November 9th, 2005, 11:31 pm
Points on hand: 2,083.00 Points
Location: Etobicoke(Toronto), Is Ontario a state?, Canada
Good Question...
Post November 9th, 2005, 11:42 pm
But as woodie man said, very very hard to weld together. It takes the perfect amount of heat and just the right application otherwise you could screw up an entire peice.
Post November 10th, 2005, 12:09 am
How into this thing are you man, lol. Cus if its just a phase cus you recently went to the park I think you shouldnt put to much money into it. But if your into it, A working model of a roller coaster has to be SOOOOO carefully calibrated to run. I reccomend looking at these, www.coasterdynamix.com , They are really nice working models.
I am working on a roller coaster model myself, Im focusing on detail more than dynamics(motion) so I'm using rubber for the track.
Post November 10th, 2005, 12:12 am
^^I believe you also can't weld aluminum in open air because of something I don't remember. That's why the insurance for an all aluminum Audi A8 is much higher than the identical steel Volkswagen Phaeton. If you dent the doors, they have to send out to Germany for new ones.
Post November 10th, 2005, 12:33 am
Points on hand: 4,391.00 Points
How large are you thinking about making this thing???
Fishing line could be good for this depending on the size of it. If you don't mind the shape the supports are in and how they are attached. Get alluminum item product, its really sturdy and easy to attach stuff too. But its not good for welding so if you absolutly want it welded dont use it.
Post November 10th, 2005, 3:11 am
u should make it real hydraulic
Post November 10th, 2005, 7:00 am
I believe it is illegal to self manufacture any product that will contain a pressurised material, so making hydraulics isn't possible. You'd have to buy the parts froma specialist company.
Also, why not just use steel for the rails? It's cheap, strong and bends easily into shape, although it is slightly heavier than its friend Aluminium
Post November 10th, 2005, 8:27 am
7 feet tall and 17 feet long
Post November 10th, 2005, 8:30 am
sorry about where i put it i just want to let you know i think i am going to use steel and soder it together but keep on posting your ideas
Post November 10th, 2005, 9:28 am
Points on hand: 2,016.00 Points
As far as i know hydraulics are not prohibited. (at least not in holland and not in the USA, but this can differ from state to state). But, you are not allowed to use very powerfull hydraulics, there is a limit set on them and i recommend you to look this up ;).
For the launch system you could also do something with elastics, its less sophistacated and a lot easier to build. Brakes. Well, you could try it with magnets like the real one, but on a lighter note: Put one + magnet in the train, and lots of - magnets in the track. Make sure they are not to strong :). Just run the train over it and put in as much till it nearly stops. Just some thoughts :). I think its going to be a hard project, but looks very fun to do :).
Post November 10th, 2005, 10:20 am
I meant you cant make your own hydraulics
Post November 10th, 2005, 10:33 am
how about pneumatics (i know i spelt it wrong)
Post November 10th, 2005, 1:24 pm
my final sciene project might perhaps be a hydro-coaster...we'll see
Post November 10th, 2005, 6:18 pm
An air launch might be hard for this too. But you might be able to get something to work by blowing in a tube.
