Board index Roller Coaster Games No Limits Coaster Weird Brake problem
Weird Brake problem
Post April 24th, 2009, 2:55 pm
Points on hand: 535.00 Points
Well, I am making an Inta. launcher (novel AND unique idea right? [;)]) I have 1 brake block along with my station for two measly trains, 5 cars each, the brake block is definitely long enough for the 5-car, if not even a 6-car train, and so is the station. When I try to test it in editor, it says there is a problem, either two many trains, increase the number of blocks (you know the message) but this time, I have PLENTY of ROOM!
WTF is going on?
Post April 24th, 2009, 3:08 pm
Points on hand: 106.00 Points
Bank: 4,290.00 Points
You sure none of the block segments in your entire ride is shorter than one train? or that the sections that should be block segments have the block segment ticked?
Post April 24th, 2009, 3:17 pm
Add another brake section somewhere!!!
Post April 24th, 2009, 3:18 pm
Yes, i'm sure, I had that down pat about a year ago...
This is a weird situation...
edit: to KS- I will try that, hold on...
edit again: to KS- it worked! Thanks ;)
Post April 24th, 2009, 4:49 pm
Yeah, on an acceletator coaster, you need one more block segments than the train count (for example, a 2 train coaster needs 3 blocks).
This is mandatory, as you do not want a train launching into a block that is occupied by another train already.
Post April 24th, 2009, 5:51 pm
you need that for every coaster[dorkhat]
