Board index Roller Coaster Games No Limits Coaster Problem with part after helix
Post July 20th, 2004, 3:28 pm
I just made a helix, and on the track immediatly after the track does a wobble and I can't for the love of god find out why it keeps doing it.
Anyone have a fix? Incase you dont know what I'm talking about below is a screen shot of the piece of track in question. The helix itself banks back to 0 degrees and then right after for some reason it banks itself a tad in the opposite direction.
[V]
Post July 20th, 2004, 4:29 pm
Points on hand: 6,164.00 Points
try to make conroll active, when it is already active, then try to make it not active
Post July 20th, 2004, 6:09 pm
Points on hand: 4,190.00 Points
Yeah - that looks exactly like what I call "Anticipation Roll." Activiating the continuous roll on a node (vertex, sry...I call them nodes) that is supposed to be banked to 0 degrees will cause this. The problem here could either be the node at the end of the helix or the node right before the break run. Anyway, like roelywoely said, uncheck the con roll box & you should be fine.
Post July 20th, 2004, 7:17 pm
Points on hand: 1.00 Points
Last edited by DjJavixxxxx on September 9th, 2014, 10:40 am, edited 1 time in total.
Post July 20th, 2004, 7:52 pm
Thanks, that fixed it
Post July 20th, 2004, 10:39 pm
Points on hand: 3,003.00 Points
jus try to strainen it ok!!
Post July 21st, 2004, 1:48 am
like i said, trying to straighten it didnt work
